دورة إدارة المشاريع الاحترافية PMP
آخر المواضيع الجديدة
صفحة 7 من 81 الأولىالأولى ... 345678910111757 ... الأخيرةالأخيرة
النتائج 61 إلى 70 من 806
التبريد والتكييف من الالف الي الياء
BSME-ASME International Conference on Thermal Engineering 31 December 2001 – 2 January 2002, Dhaka Optimal Performance of an Endo-reversible Solar
  1. #61
    عضو متميز الصورة الرمزية حسن هادي
    تاريخ التسجيل
    Nov 2006
    صفحة الملتقى الرسمية على الفيس بوك .. مجموعة المهندسين العرب .. follow us on twitter...
    Optimal Performance of an Endo-reversible Solar Driven
    Sorption Refrigeration System
    K.C.A. Alam and M. M.A. Sarker
    Department of Mathematics,
    Bangladesh University of Engineering and Technology
    Dhaka-1000, Bangladesh
    Abstract:
    This article deals with the thermodynamic optimization of a solar driven sorption
    refrigeration system. An externally irreversible but internally endo-reversible model has
    been emp loyed to analyze the optimum conditions of a sorption cooling system driven by
    a solar collector. The operating conditions for maximum refrigeration load are
    determined. It is shown that the system gives its highest capacity if the thermal
    conductances of the heat exchangers are distributed properly. Results also show that
    optimum refrigeration load increases with the increase of collector stagnation and
    required room temperature increase and decreases as the ratio of collector size to the
    cumulative size of all four heat exchangers increases. It may also see that the optimal
    thermal conductance of the evaporator expands with the expense of the optimal thermal
    conductance of solar collector as collector stagnation temperature, refrigerated room
    temperature increase.
    1. Introduction
    In recent years, heat driven sorption refrigeration system have drawn considerable
    attention due to its lower environmental impact and large energy saving potential.
    Another interesting feature of this system is that, the chiller/heat pump can be operated
    by thermal heat such as waste heat from industries or by solar heat. From this context, a
    number of researchers investigated the performance of sorption heat pumping/
    refrigeration system driven by waste heat or by renewable energy sources. Among these,
    for solar cooling, worked by Pons and Guilleminot(1986 ), Zhang and Wang (1997) for
    automobile cooling and Saha et. al (2000), Alam et. al. (200a,b) for waste heat utilization.
    While the feasibilty of the system performance has been studied, the investigation on
    optimum design of a heat driven refrigeration system is scare. In 1993, Sokolov and
    Hersagal (1993) apply optimization techniques to optimize the system performance of a
    solar driven year round ejector refrigeration. Vargas
    et. al. (1996) investigated the
    optimal condition for a refrigerator driven by solar collector considering the three heat
    transfer irreversibilites. Later, Chen and Schouten (1998) discussed the optimum
    performance of an irreversible absorption refrigeration cycle in which three external heat
    transfer irreversibilities have been considered.
    Recently, Alam et. al. (2001) modeled and optimized a solar driven endo-reversible
    adsorption refrigeration system by considering the four heat transfer irrevesibilities. In
    that article, authors showed that the maximum refrigeration effect could be achieved by
    allocating the heat exchangers inventory properly. They also showed that the optimal
    thermal conductance of the heat exchangers that take heat from the heat source is almost
    equal to the thermal conductance of the heat exchangers that release to the external
    ambient. In the present study, the model of Alam et. al. (2001) has been utilized to
    investigate the optimum refrigeration load in different conditions. The primary objective
    of this study is to determine the optimum allocation of thermal conductancee between the
    collector and evaporator.
    2. Mathematical Model
    The main components of a solar driven sorption refrigeration system are a solar collector,
    a desorber, a sorber, a condenser and an evaporator, as shown in Fig. 1. In a sorption
    cycle, the working fluid execute a cycle and exchange heat to the heat exchange
    من مواضيع حسن هادي :
  2. #62
    عضو الصورة الرمزية eng_hany003
    تاريخ التسجيل
    Aug 2006
    دائرة التبريد التى تعمل بالإنضغاط هى دائرة التبريد البسيطة والموجودة فى الثلاجة المنزلية وهى مكونة أساساً من أربع عناصر اساسية
    1 - الضاغط وهو بمثابة القلب ووظيفتة الأساسية هى سحب ( وسيط التبريد) من المبخر وضغطة الى المكثف
    2 - المكثف وهو المسئول على التخلص من الحرارة الموجودة فى وسيط التبريد وفية يتحول وسيط التبريد من الحالة الغازية الى الحالة السائلة نتيجة فقد الحرارة الى الجو والأضغاط
    3 - صمام التمدد وهو المسئول عن المحافظة على فرق الضغط بين المبخر والمكثف وانسياب وسيط التبريد الى المبخر بالقدر المطلوب لاتمام عملية التبريد
    4 - المبخر وهو المسئول على امتصاص الحرارة من الحيز المطلوب تبريدة الى وسيط التبريد
    وسيط التبريد هو مركب كيميائى درجة غليانة منخفضة جداً( غاز الفريون يغلى عند -27 درجة مئوية) عندما يكون وسيط التريد بالمبخر ونتيجة لعمل الضاغط وتأثير صمام التمدد يكون تحت ضغط منخفض يتبخر وسيط التبريد ( يدخل وسيط التبريد الى المبخر فى الحالة السائلة ) ولكى يتبخر فهو بحاجة الى الحرارة التى يمتصها من الحيز المحيط ( جرب وضع كمية من الكحول على يدك تشعر بالبرودة نتيجة تبخر الكحول يمتص الحرارة من يدك )
    بعد ذلك يقوم الضاغط على سحب الغاز من المبخر ويقوم بضغطه الى المكثف وفى المكثف يرتفع ضغط الغاز ومن خلال المكثف يفقد الغاز الحرارة الى الجو الخارجى ونتيجة ارتفاع الضغط وفقد الحرارة يتحول الغاز الى سائل ومنه الى صمام التمدد الذى يقوم بعملية الخنق لوسيط التبريد والمحافظة على فرق الضغط بين المكثف والمبخر
    أعتذر لعدم وجود صور توضيحية حيث ان هذه اول مشاركة لى فى المنتدى
    الرجاء لمن يعرف برنامج memate اريد البرنامج وكلة السر
    من مواضيع eng_hany003 :
  3. #63
    مشرفة
    تقوى الله Don't Avatar
    تاريخ التسجيل
    Aug 2005
    Exclamation إغـــــــــــــــــلاق الموضــــــــــــــــــــوع
    أخواتي و إخواني الكرام في الله .. لعلكم بخير بإذن الله تعالي
    نظراً لما نعاني منه من نقل المشاركات والاستفسارات للموضوعات المخصصة لها ، فسوف نقوم بإذن الله تعالي
    بإغــــــــــــــــــــــــلاق الموضــــــــــــــــــــــــوع
    فالموضوع كما أوضحنا من قبل أنه مخصص للشرح فقط كي يحقق الأعضاء أعلي نسبة تحصيل لما يريدون دون عناء البحث ..
    وعلي من يريد إضافة شرح علي الموضوع .. فعليه بمراسلة أحد مشرفين القسم أو المشرفين العموم كي يتفضل مشكوراً بفتح الموضوع لمشاركته التي تضيف ما هو جديد للأعضاء .. بإذن الله تعالي
    وفي حالة رغبة المشاركة بمداخله علي الموضوع .. فليتفضل مشكوراً في هذا الموضوع
    مداخلات موضوع التبريد والتكييف من الألف إلى الياء
    من خلال الرابط التالي
    http://www.arab-eng.org/vb/showthread.php?t=17223
    وفي حالة الاستفسار عن اي جزء في هذا الموضوع .. فليتفضل مشكوراً في هذا الموضوع
    الاستفسارات في التبريد والتكييف
    وجزاكم الله كل خير
    والله الموفق ،،، والله الهادي ،،، والله المستعان ،،،
    ليس عليك هداهم .. ولكن الله يهدي من يشاء .
    إنك لا تهدي من أحببت .. ولكن الله يهدي من يشاء .
    الحمد لله الذي هدانا لهذا .. وما كنا لنهتدي لولا أن هدانا الله .
    من مواضيع تقوى الله :
  4. #64
  5. #65
  6. #66
  7. #67
  8. #68
    عضو فعال جداً الصورة الرمزية 3atooora
    تاريخ التسجيل
    Mar 2010
    الموضوع جميل و مهم جزاك الله كل خير
    من مواضيع 3atooora :
  9. #69
    kdorrah Don't Avatar
    تاريخ التسجيل
    Feb 2010
    جزاك الله اللف خييييييييييير معلموات قيمه جدااا مع انى كنت مفكر انو كارير هو اول من اخترع جهاز التكييف سنه 1935
  10. #70
المواضيع المتشابهه
  1. شرح اتوكاد من الالف الى الياء
    بواسطة kilani2010 في المنتدى الهندسة المـدنيـة - عام
    مشاركات: 5
    آخر مشاركة: 15-02-2012, 12:56 PM
  2. الحديد من الالف الى الياء
    بواسطة احمد عباس الخطيب في المنتدى هندسة الفلزات والمواد
    مشاركات: 1
    آخر مشاركة: 28-02-2009, 11:03 AM
  3. المواد (من الالف إلى الياء)
    بواسطة م.جمال العبري في المنتدى الهندسة المـدنيـة - عام
    مشاركات: 4
    آخر مشاركة: 03-09-2006, 06:59 PM
ضوابط المشاركة
  • لا تستطيع إضافة مواضيع جديدة
  • لا تستطيع الرد على المواضيع
  • لا تستطيع إرفاق ملفات
  • لا تستطيع تعديل مشاركاتك
عن ملتقى المهندسين العرب
    يُعتبر ملتقى المهندسين العرب من أوائل وأكبر المواقع الهندسية حيث تم تأسيسه منذ عام 2001م ويهدف إلى نشر المعرفة الهندسية وتقديم كل ما له فائدة للمهندسين والمهتمين من خلال أقسامة العلمية والهندسية المتعددة بالإضافة إلى وجود أقسام عامة تستقطب الكثير لمختلف النقاشات الهادفة.
مواقع صديقة
تابعنا على
Twitter Facebook
The owner and operator of the site is not responsible for the availability of, or any content provided.
Topics that are written in the site reflect the opinion of the author.
Search Engine Optimization by vBSEO
