العودة   ملتقى المهندسين العرب > الملتقى الهندسي > هندسة التبريد و التكييف
هندسة التبريد و التكييف ................ بإشراف : المهندس الكويتي, م. عبد المنعم, م.محمد عبد الفتاح سيد
أدوات الموضوع التقييم: تقييم الموضوع: 10 تصويتات, المعدل 4.50.
قديم 08-12-2006, 11:48 AM   رقم المشاركة : [61]
حسن هادي
الصورة الرمزية حسن هادي
حسن هادي
BSME-ASME International Conference on Thermal Engineering
31 December 2001 – 2 January 2002, Dhaka
Optimal Performance of an Endo-reversible Solar Driven
Sorption Refrigeration System
K.C.A. Alam and M. M.A. Sarker
Department of Mathematics,
Bangladesh University of Engineering and Technology
Dhaka-1000, Bangladesh
Abstract:
This article deals with the thermodynamic optimization of a solar driven sorption
refrigeration system. An externally irreversible but internally endo-reversible model has
been emp loyed to analyze the optimum conditions of a sorption cooling system driven by
a solar collector. The operating conditions for maximum refrigeration load are
determined. It is shown that the system gives its highest capacity if the thermal
conductances of the heat exchangers are distributed properly. Results also show that
optimum refrigeration load increases with the increase of collector stagnation and
required room temperature increase and decreases as the ratio of collector size to the
cumulative size of all four heat exchangers increases. It may also see that the optimal
thermal conductance of the evaporator expands with the expense of the optimal thermal
conductance of solar collector as collector stagnation temperature, refrigerated room
temperature increase.
1. Introduction
In recent years, heat driven sorption refrigeration system have drawn considerable
attention due to its lower environmental impact and large energy saving potential.
Another interesting feature of this system is that, the chiller/heat pump can be operated
by thermal heat such as waste heat from industries or by solar heat. From this context, a
number of researchers investigated the performance of sorption heat pumping/
refrigeration system driven by waste heat or by renewable energy sources. Among these,
for solar cooling, worked by Pons and Guilleminot(1986 ), Zhang and Wang (1997) for
automobile cooling and Saha et. al (2000), Alam et. al. (200a,b) for waste heat utilization.
While the feasibilty of the system performance has been studied, the investigation on
optimum design of a heat driven refrigeration system is scare. In 1993, Sokolov and
Hersagal (1993) apply optimization techniques to optimize the system performance of a
solar driven year round ejector refrigeration. Vargas
et. al. (1996) investigated the
optimal condition for a refrigerator driven by solar collector considering the three heat
transfer irreversibilites. Later, Chen and Schouten (1998) discussed the optimum
performance of an irreversible absorption refrigeration cycle in which three external heat
transfer irreversibilities have been considered.
Recently, Alam et. al. (2001) modeled and optimized a solar driven endo-reversible
adsorption refrigeration system by considering the four heat transfer irrevesibilities. In
that article, authors showed that the maximum refrigeration effect could be achieved by
allocating the heat exchangers inventory properly. They also showed that the optimal
thermal conductance of the heat exchangers that take heat from the heat source is almost
equal to the thermal conductance of the heat exchangers that release to the external
ambient. In the present study, the model of Alam et. al. (2001) has been utilized to
investigate the optimum refrigeration load in different conditions. The primary objective
of this study is to determine the optimum allocation of thermal conductancee between the
collector and evaporator.
2. Mathematical Model
The main components of a solar driven sorption refrigeration system are a solar collector,
a desorber, a sorber, a condenser and an evaporator, as shown in Fig. 1. In a sorption
cycle, the working fluid execute a cycle and exchange heat to the heat exchange
حسن هادي غير متواجد حالياً
قديم 13-01-2007, 09:00 AM   رقم المشاركة : [62]
eng_hany003
eng_hany003 يستحق التميز
دائرة التبريد التى تعمل بالإنضغاط هى دائرة التبريد البسيطة والموجودة فى الثلاجة المنزلية وهى مكونة أساساً من أربع عناصر اساسية
1 - الضاغط وهو بمثابة القلب ووظيفتة الأساسية هى سحب ( وسيط التبريد) من المبخر وضغطة الى المكثف
2 - المكثف وهو المسئول على التخلص من الحرارة الموجودة فى وسيط التبريد وفية يتحول وسيط التبريد من الحالة الغازية الى الحالة السائلة نتيجة فقد الحرارة الى الجو والأضغاط
3 - صمام التمدد وهو المسئول عن المحافظة على فرق الضغط بين المبخر والمكثف وانسياب وسيط التبريد الى المبخر بالقدر المطلوب لاتمام عملية التبريد
4 - المبخر وهو المسئول على امتصاص الحرارة من الحيز المطلوب تبريدة الى وسيط التبريد
وسيط التبريد هو مركب كيميائى درجة غليانة منخفضة جداً( غاز الفريون يغلى عند -27 درجة مئوية) عندما يكون وسيط التريد بالمبخر ونتيجة لعمل الضاغط وتأثير صمام التمدد يكون تحت ضغط منخفض يتبخر وسيط التبريد ( يدخل وسيط التبريد الى المبخر فى الحالة السائلة ) ولكى يتبخر فهو بحاجة الى الحرارة التى يمتصها من الحيز المحيط ( جرب وضع كمية من الكحول على يدك تشعر بالبرودة نتيجة تبخر الكحول يمتص الحرارة من يدك )
بعد ذلك يقوم الضاغط على سحب الغاز من المبخر ويقوم بضغطه الى المكثف وفى المكثف يرتفع ضغط الغاز ومن خلال المكثف يفقد الغاز الحرارة الى الجو الخارجى ونتيجة ارتفاع الضغط وفقد الحرارة يتحول الغاز الى سائل ومنه الى صمام التمدد الذى يقوم بعملية الخنق لوسيط التبريد والمحافظة على فرق الضغط بين المكثف والمبخر
أعتذر لعدم وجود صور توضيحية حيث ان هذه اول مشاركة لى فى المنتدى
الرجاء لمن يعرف برنامج memate اريد البرنامج وكلة السر
eng_hany003 غير متواجد حالياً
قديم 06-02-2007, 06:57 PM   رقم المشاركة : [63]
N.C
مشرفة سابقة
N.C يستحق التميز
Exclamation إغـــــــــــــــــلاق الموضــــــــــــــــــــوع
أخواتي و إخواني الكرام في الله .. لعلكم بخير بإذن الله تعالي
نظراً لما نعاني منه من نقل المشاركات والاستفسارات للموضوعات المخصصة لها ، فسوف نقوم بإذن الله تعالي
بإغــــــــــــــــــــــــلاق الموضــــــــــــــــــــــــوع
فالموضوع كما أوضحنا من قبل أنه مخصص للشرح فقط كي يحقق الأعضاء أعلي نسبة تحصيل لما يريدون دون عناء البحث ..
وعلي من يريد إضافة شرح علي الموضوع .. فعليه بمراسلة أحد مشرفين القسم أو المشرفين العموم كي يتفضل مشكوراً بفتح الموضوع لمشاركته التي تضيف ما هو جديد للأعضاء .. بإذن الله تعالي
وفي حالة رغبة المشاركة بمداخله علي الموضوع .. فليتفضل مشكوراً في هذا الموضوع
مداخلات موضوع التبريد والتكييف من الألف إلى الياء
من خلال الرابط التالي
http://www.arab-eng.org/vb/showthread.php?t=17223
وفي حالة الاستفسار عن اي جزء في هذا الموضوع .. فليتفضل مشكوراً في هذا الموضوع
الاستفسارات في التبريد والتكييف
http://www.arab-eng.org/vb/showthread.php?t=14983
وجزاكم الله كل خير
والله الموفق ،،، والله الهادي ،،، والله المستعان ،،،
ليس عليك هداهم .. ولكن الله يهدي من يشاء .
إنك لا تهدي من أحببت .. ولكن الله يهدي من يشاء .
الحمد لله الذي هدانا لهذا .. وما كنا لنهتدي لولا أن هدانا الله .
ربِ إغفر لي ولوالدي وللمؤمنين والمؤمنات وللمسلمين والمسلمات الأحياء منهم والأموات
حياتي بلا أغانــــي .. لا تنسونا من صالح الدعاء
أعوذ بالله أن أكون جسراً تعبرون به إلي الجنة ويسقط هو في النار
ثم أعوذ بالله أن أذكركم به وأنساه
N.C غير متواجد حالياً
الالف, التبريد, الى, الجاء, والتكييف
الساعة الآن 07:17 PM.
