النتائج 1 إلى 10 من 37
    التصميم الميكانيكي machine design
    التصميم الميكانيكي :machine design
    الرابط التالي لموقع التصميم الميكانيكي مفيد لطلبة الدراسات الهندسية في اختصاص التصاميم وعلى كافة مراحل الدراسة ( البكالوريوس أو الماجستير أو الدكتوراه ) :
    يتضمن الموقع :
    INTRODUCTION
    NOMENCLATURE
    DESIGN
    What is Design?; why do we design ?; how do we design - problem statement, creating a bank of solution candidates, constraints & criteria, practicalising the candidates, evaluating the candidates, the feasibility study; where do we go from here?; more advanced considerations.
    Appendices - an improvement problem; analysis of a spring driven vehicle; springs as energy stores; extract from JCH Roberts, Creativity.
    STRESS, STRENGTH AND SAFETY
    Safety factor; stress concentration; static indeterminacy; elementary load building blocks; stress & strain resolution; failure theories; putting it all together; design equations for static round shafts; power transmission shafts.
    Appendix - indeterminate assemblies of multiple components.
    MISCELLANEOUS STRENGTH TOPICS
    Castigliano's theorem; curved beams; asymmetric bending; contact stresses.
    SPRINGS
    Types of springs; close coiled round wire helical compression springs; the spring characteristic; stresses & stiffness; buckling; wire materials; presetting; fatigue loading; spring design.
    Appendix - presetting a torsion bar.
    THREADED FASTENERS
    Thread geometry; screw thread mechanics; static failure; loads in an elastic bolted assembly; preload and its control; fluid pressurised joints; bolt fatigue; non-uniformly loaded bolt groups.
    WELDED JOINTS
    Fillet welded joints; geometric properties of lines; traditional analysis; throat stresses and joint safety; unified analysis; conclusion.
    Appendix - the compliant lap joint.
    CYLINDERS
    Axial stress; thin cylinders; thick cylinders; design equations; strains; autofrettage; compound cylinders; torsional loading.
    PRESSURE VESSELS
    Corrosion; welded joint efficiency; thin ****ls of revolution - heads; compensation; pipes and flanges; inspection openings; supports; design.
    SQUIRREL CAGE MOTORS
    Characteristics of a steady load and of a motor; matching a motor to a given steady load; acceleration; periodic loading. Hydraulic couplings.
    Appendix - integration in practice.
    V-BELT DRIVES
    Overall geometry; kinetics; fatigue; drive selection; effectiveness; approximate solutions; V-flat and pivoted motor drives. Traction mechanics.
    Appendix - commercial selection tables.
    BRAKES
    System dynamics; linings. Brake analysis: translating brakes - short and long shoes; drum brakes - short, long rigid and hinged shoes; twin shoe brakes. The braked wheel; braking of vehicles; wheel lock; the vehicle and brake control characteristics.
    SPUR GEARS
    Overall kinetics of a gear pair; epicyclic trains; conjugate tooth action; the involute tooth; the generation process - tooth systems; profile shift; gear meshing. Gear failure - reliability; tooth forces; bending strength; pitting resistance; varying duty.
    Appendices - continued fractions; geometry of the involute gear tooth.
    BUCKLING
    Buckling of thin walled structures; stability of equilibrium; effects of imperfections. Submerged pipelines. Practical columns - design equations.
    FRACTURE MECHANICS
    Fatigue of ductiles; stress concentration; linear elastic fracture mechanics; plasticity; yielding fracture mechanics - the R6 technique; fatigue crack growth. Crack growth kinetics.
    FINITE ELEMENTS
    Linear 1-networks; extension to 2- and 3-networks. The Rayleigh-Ritz method. Finite element theory applied to elasticity - equilibrium of the discretised body; element stiffness. Implementation; condensation and bandwidth; discretisation.
    Appendices - the refining process; "FEM1" User's Guide.
    جزاك الله خير وجعله في ميزان حسناتك
    بصراحه موضوع جميل
    الصورة الرمزية يونس فاخر
    شكرا اخي engbasb على الرد الجميل
    الصورة الرمزية عبد الرحمن الجمل
    حياك الله يااخي وسدد خطاك وجعل ا لجنه مثو اك وجمع بيني وبينكم في جنة ربكم
    اخاك عبدالرحمن الجمل
    مصر كلية الهندسه جامعة بنها
    وجزاك الله خيرا
    الصورة الرمزية ماجد جلميران
    بارك الله فيك اخي ووفقك
    بارك الله فيك وكتر من امثالك
    الصورة الرمزية مهندس مواد 84
    تسلم خيوووووووووووووووو
    الصورة الرمزية مهندس حطاب
    و الله الاستاذ يونس ما قصر
    لا اله الا انت سبحانك اني كنت من الظالمين
    بارك الله فيك وجزاك خيرا
    عضو فائق التميز
    Received: 97
    بارك الله فيك يا أخى
