The main purpose of the AGARD Flight Test Instrumentation Series is to provide monographs on the more important aspects of flight test instrumentation as a reference for the flight test engineer. The first monographs in the series discuss in-flight temperature measurements, fuel flow and engine rotation speed measurements, open and closed-loop accelerometers and magnetic tape recording; they will be followed by others. In this introductory volume it has been tried to highlight the main lines along which a flight test instrumentation system is developed, to indicate the main steps which must be taken during the design and to define the basic concepts used by each specialist. A flight test system is considered to include both the data collection and the data processing systems.
Descriptors : *FLIGHT TESTING, *INSTRUMENTATION, *AIRCRAFT EQUIPMENT, SIGNAL PROCESSING, INFLIGHT, RECORDING SYSTEMS, ONBOARD, MULTICHANNEL COMMUNICATIONS, TELEMETER SYSTEMS, CHECKOUT EQUIPMENT
Publisher: AGARD
* Number Of Pages: 168
* Publication Date: 1994
* ISBN-10 / ASIN: 9283507312
Code:
http://rapidshare.com/files/13864961...ngineering.rar
